1 - 13 of 13 Posts
Can anyone help me out I purchased my 03 LT/EXT TB and there is no manual. I was playing around with the overdrive switch but it does'nt seem to be working. Anyone able to give me pointers. There is no indication of it being engaged.
i need a physical booklet so when i am in the car i can refer to the manual. To print it will be very large binder. Thanks though. The overdrive switch is to the left of the steering wheel by the wiper controls. I know there is a push button then there is a lil switch with an O, an icon that looks like a clock in some sort, then a + sign.
I do not know what kind of printer you have but mine will allow me to set the page size and print the even pages. Then put the pack of paper back into the printer with the blank side up and print the odd pages. Bingo, the same book that came with the vehicle.
yeah u r right and what a moron i am. I meant cruise control. My field office has a real cheap ass printer that would take all day to make a booklet copy. But as far as that I'll read up and follow up.
The instrument panel does indeed have a cruise-engaged light. Just read the PDF of the manual and make sure you're turning it on properly.
If it doesn't work, there are some engine controller error codes that will inhibit the cruise control. You would have to get a code reader to see what's in memory.
Northwest Chapter
Either a light that says "CRUISE" or is a picture of a speedometer with a line through one side will come on when its engaged (both are green). Make sure you have the switch actually in the on position (the switch on the frontside of the stalk).
1 - 13 of 13 Posts
