2003 chevy trailblazer_ls_ext
I just received my Trailblazer service manual on CD ROM from GM Parts and Operations. Here is a direct quote concerning the operation of the fan clutch:
The PCM commands the cooling fan to 100% under the following conditions:
*Engine coolant temperature exceeds approximately 129°C (264°F).
*The transmission oil temperature exceeds approximately 151°C (304°F).
*A/C refrigerant pressure exceeds 1655 kPa (240 psi).
*When certain DTC's set. These include P0116, P0117, P0118, P0125, P1481, P1482, and P1484.
After reading many of the posts here concering engine a trans temps during towing I thought it would be a good idea to post this here. What alarms me is the extreme temps that these are allowed to reach before 100% cooling is commanded.
A few questions:
1) My temp gauge only goes up to 260 so why is the coolant allowed to reach 264* before 100%? Doesn't a 50/50 mix of ethylene glycol/water start to boil at this temp under 15 psi?
2) Dosen't the transmission fluid begin to cook at temps below 304*. My '03 TB came with Dexron 3 or 4 not Dexron 6.
3) I know that the fan does cool at a reduced coupling (< 100%) below these temps but why would we ever want them to get this high for the sake of saving a little fuel?
4) Can the PCM be re-programmed to command 100% at reduced temps? Would a tune do this?
Please,.. any and all comments welcome!
2002 olds bravada
hm..its funny how the PCM commands the fan clutch to run at full potential AFTER everything starts to boil up and fry..:rolleyes:
2002 olds bravada
I'm pretty sure anyone with a TechII can command the PCM when to turn the fan clutch onto full power..
