21 - 21 of 21 Posts
I think your air flow velocity would increase by adding the nozzle (small hole) however, your flow rate would decrease (less volume of air). Since you are trying to get as much air into the intake as possible, you do not want to reduce your flow rate. If you can speed up the same volume great, but speeding up air by reducing the volume is not advised.
i.e. water pistols shoots far, but only a little bit of water, hose doesn't go very far, but alot more water.
21 - 21 of 21 Posts
