I have a '03 trailblazer LT EXT with the inline 6, loaded except for sunroof.
My wife was driving a couple of weeks back and the engine died. After pulling over it started back. That happened a couple of more times. Then when getting in to start, the gauges would go crazy, moving wildly before going normal, sometimes it would then start and sometimes not.
Now it will not start at all. The engine will not turn over, gauges move wildly, and also sometimes displays 'service brake system'. The airbag and brake lights also stay on even when the gauges go back to normal position.
Some of you are mechanics and I have read posts that say bad ignition switch. This may be my case as well, but what about the brake message?
Do any of you think this is one in the same?
I have been doing my own repairs for over 20 years and can do so if I can find the problem, I have checked all wiring as best I can, swapped batteries and cleaned posts and grounds and reseated and checked fuses.
Any help from you guys would be appriciated, on any problem that is even close to this one to give me ideas.
