101 - 115 of 115 Posts
My lifted 2002 envoy slt
FRONT - 3 INCH LEVELING LIFT
REAR - 2 INCH LEVELING LIFT
REAR - EATON G80 LOCKER
TIRES - 265/70/17 Definity Dakota A/Ts
WHEELS - Stock 17" Chrome + 1.5'' Wheel Spacers
NEXT 2 MONTHS - FRONT PUSH BAR, REAR PUSH BAR, LED ROOF LIGHT BAR, 10,000LB WINCH, CUSTOM SKID PLATE.
2003 gmc envoy_sle
This is my Envoy there are many like it but this one is mine
:hail:Marks MC 2.5 lift, 1.5 spacers, Goodyear Wrangler 265-70-R17, Rims stock painted black, Westin Brushguard, Light bar:)hail:James Downing post)
finally got mark's 3" suspension lift installed
everything else is stock
thanks Mark, awesome doing business with you!
Tire Size and Type: 265/70/17 Bridgestone Dueler AT RH-S
Rim Size and Type: 17" Tahoe Z71
Lift Ammount and Type: MarkMc 2.5" suspension lift all around w/07 Tahoe rear springs and shocks, all Bistein HD
Spacer/Adapters: MarkMC 6x5>6x5.5
:thumbsup:
265/65/17 Michelin Ltx At2 tires
17x8 22mm Incubus wheels
Stock suspension for now plan on marks 2.5 lift
2003 chevy trailblazer_ltz
315 / 70 / R17 - Nitto Trail Grappler M/T
Method Race Wheels Double Standard 17x8.5
MarkMC's 1.5 wheel adapters
BDS 2" lift, Lift Meister 3" Body, Z71 Rear Springs, MAssive Speed Adjustable Upper & Lower Control Arms, Massive Speed Adjustable Rear Panhard Bar, Spider Differential Rock Guard By Purple Cranium, MBD Oil & Radiator Skid Plates
Tire Size and Height: 285/75R16 Goodyear Wrangler Duratrac
Wheel Size and Type: 16x7.5 Black powder coated H3's
Lift Amount and Type:
Front: LiftMeister 2.5"in spacer, Bilstein HD Shocks
Rear: LiftMeister 2"in block, Avalanche Z71 Springs/Shocks
Body: N/A
Wheel Spacers: 1.5"in adapters from wheeladapters.com
Such a nice rig! What gear do you have with the 33s?
Marks 2.5" lift, Marks 6x5 to 6x5.5 1.5" thick adapters, American Eagle Alloy wheels Series 015, and Goodyear Wrangler Duratracs 265/70/17. More pics to come when I get a chance.
Finally got it lifted
After a long time lurking finally pulled the trigger.
2.5" Liftmeister Lift
No wheel spacers
Bilstein HD Front Struts
Skyjacker Rear Shocks
BFG All-Terrain T/A KO2s 255/70R17
2006 chevy trailblazer_ss_lt
My TBSS on 35's
06 TBSS / 5" lift / 285/75R18's (35" tires):
Front - 3" from strut lift blocks; 1" from strut lift (swapped to stock TB struts); 1" coil spacer (rubber spacer below coil).
Rear - 4" lift from Jeep JK 4" dual rate coils. Took out airbags and added 1/2" coil spring spacers to sit level with front.
2004 trailblazer lt
Tires: 285/70/17 centennial mud terrain.
wheels: original
Lift: 3” front bds spacerand moog struts. Flipped and reversed upper control arms to correct severe caster angle without “proper lift kit.
lift: 2” rear with Tahoe springs and bilstien shocks.
Spacers: 2”.
Mandatory: all new moog control arms and bushings and tie rods.
