After recently replacing a dead battery, my odometer and gear indicator lamps stopped working. The other lights on the dashboard still light, just not the odo. & gear lamps. There does not appear to be a separate fuse for these, so I fear something else is wrong. Any clues or advise would be appreciated.
There are multiple bulbs that back light the instrument panel. You probably need to replace 1 or more. I haven't had to replace any yet so I haven't seen the backside of the cluster yet. I would suggest that if you are going to pull the cluster and replace the bulbs that you replace them with LEDs that will live a lot longer than regular bulbs.
I'm sure someone will come along with step by step instructions on how to replace them, what bulb number you will need and how many.
I just re-did my cluster with LEDs over the weekend. The gear-selection indicators and odometer are not lit using traditional incandescent lighting. They use their own displays with integrated lights. If they are both out, I would think it is probably a fuse issue. If it's not a fuse, they must share another common component, separate from the remainder of the cluster.
what if the lights are going off and on intermintently? Also now the side seat controls on the door are also not working?
