1 - 3 of 3 Posts
2004 gmc envoy_sle
Recently i am getting a clinking noise(metal hitting against metal) when i apply the brakes over rough surface and also when i drive over certain bumps on the road. Gmc envoy 2004 sle (83,400 Miles). My mechanic shop is closed due to the COVID19. I physically checked under the vehicle and did not see anything hanging. What can it be any advise is appreciated, Thanks
The biggest offender is usually the sway bar end links, but there are many other suspension components that can also be suspect. Need to get under and inspect everything.
2004 gmc envoy_sle
Thank You EnvoyBoy, my mechanic shop has finally opened, it was the upper trailing control arm was broken on the left side.
1 - 3 of 3 Posts
