2009 chevy trailblazer_ls
Hey I have no power to Ac compressor at all. I have power to ac fuse but no power to relay in fuse box . I checked compressor its grounded but no pwer there does pcm control what power goes to ac. I have power inside of my TBlazer at switch. New compressor as well
Not sure which HVAC system you have, but check the following fuses; underhood fuse box - fuse# 22 & 30, rear fuse box - fuse #36. If fuses are good and you have no voltage on both sides of any of these fuses, there is a problem with the fuse box or a wiring issue going to the fuse box. Attached are schematics for the manual system.
