This is the craziest issue....No crank, no start. I rebuilt the engine, re-installed. No Crank and no start.
I have tested all I have thought possible. Any new suggestions would be great.
Here is what was tested:
- New battery
- Manually triggered stater via ground signal on relay - Cranks
- Relay good
- starter good
- PCM replaced / same condition new or old PCM
- Via tech 2 - crank volt detected
- voltage tested to both relay points control circuit and starter enable
- Via tech 2 - park switch in proper position and detected
- all fuses 17, 22, 34, 24 checked and good
Car was cranked via manual trigger to starter, while in run position, still wouldn't fire.
PCM not sending ground signal to the relay control circuit.
All connectors to all sensors verified connected.
Anyone have any insight to this?
Many thanks!
- New battery
- Relay good
- starter good
Many thanks!
