1 - 1 of 1 Posts
Did rotors and pads in April because I noticed grooves.
By end of May grooves were back in front rotors
Also hear slight rubbing of pads first 5 minutes of driving
Temps affect brake pedal pressure as follows
90+ rubbing noise very stiff pedal
80+ intermittent rubbing good pressure
70s good pressure noise only in the first 5 minutes
60s low pressure at first then fine after a while of running rubbing noise first five
50s no pressure from front pads only rear pedal goes to floor
There doesn't seem to be pulling to a certain side when braking so sticking pads just be both sides
Grooves on both front rotors both sides
Truck leaks no fluids what so ever
Reservoir is full no drainage or leaking
Did not bleed brakes when pads changed
The problem is localised to the front brakes only.
Both sides pretty evenly
The truck seemed like it may have sat over grass fora while noticed rust but not enough to think flood so I assume parked over grass for prolonged period of time
Rear rotors had been just don't before I bought the truck works fine.
My thoughts on the culprit is
Bad/dirty/rusty/torn boot front calipers
Possible bad front brake lines
1 - 1 of 1 Posts
