It seems like my little TB has the flu! Alot of strange symptoms lately. Other than the security light coming on and off by itself and the 4x4 selector light either not on or blinking then going off. (sometimes they stay on an work fine) but wth the recent snow in chicago I went and put it in 4x4 hi drove some...came to a intersection to turn at...start to fishtail..and think 4x4 hi seems different than last year!!
Further investigation revealed 4x4hi not working as well as a4x4. Placed in N and tried 4x4lo. put it into drive and it worked. switched back and still only 2wd.
I have read the threads about the fuse #8 and will try that when I can get to the fuse box. Could this be a TCCM issue? Does the PCM have any effect or link to the 4x4? Could it just be the selector switch? One last question..what noise should I be hearing while he 4x4 should be engaging? When I use to switch last year I could hear a slight hum for about a sec or 2. When I try it now I dont hear anything except 4x4lo and its a much louder hum and then a clunk if that makes sence:undecided
