Hi everyone, heres my problem, my 2002 envoy is always 2wd not matter what the switch says. the light on the switch blinks for a long time and then goes into position, but its not actually 4auto, or 4hi. As soon as i turn the switch to 4lo the light blinks and then goes out, and the Servive 4wd light comes on? also the t/c wont go into Neutral. the red N only illumnates for a sec when you turn the key. then goes out, nothing happens when i turn the switch over to N. i can hear the front actuator when i turn the switch. and i hear the encoder motor but i sounds like i binds and retries. ive tried the #8 fuse thing, nothing-same stuff. :confused: thanks
Sure sounds like the encoder motor. Or internal binding in the transfer case - a lot more expensive to fix that. Good luck!
Thanks for the reassurance, im pretty sure its the encoder motor becuase it just stopped working one day. motor prolly just had enough thanks agian
