1 - 13 of 13 Posts
My mechanic said the problem I was having with my 07 Trailblazer was very prevalent. The fan is electrically controlled and that system failed, causing the freon to run out thereby having no cold air. The part is $400.00 plus labor and freon. Not very good news for a two year old vehicle, even though it has 60000 miles on it. Those are very easy driven miles. My bad luck. I joined mainly to see if others had the same problem. :thx
I'm sorry but freon doesn't "run out" it leaks out. The fan clutch going bad won't make it just dissappear. They are two completly seperate sytems.
oh and Welcome from the far northern Chicago 'burbs
:tiphatwelcome, and the two are not directly related. AC is a sealed system and no way can a bad fan cause it to leak! Sounds to me like someone blew smoke up someones a$$! Get in writing and then proceed to make an example of this idiot!
1 - 13 of 13 Posts
