1 - 3 of 3 Posts
im getting ready to install 2 amps. i got a polk C500.1 (500wx1 2ohm) and an alpine mrp-f600 (100wx4 4ohm). i bought a rockford fosgate multi-amp 4awg kit. my question is: would i get enough power output to run these 2 amps from the rear fuse block or would it be better to run it to the battery? it would be so much easier to go from the fuse block but i want to be sure i get plenty of power. im also getting 2 pairs of polk db6501 component systems and a polk db1212 sub. i cant wait to get it all installed, should sound pretty good. anyways, thanks in advance for your help.:):):thx
I agree run it from the battery. And change the wire from the alternator to the battery to 4awg also. Stock is 8awg. Which means even if you install the amp power wire at 4awg it will act like an 8awg. Sort of like your only as good as the weakest link.
1 - 3 of 3 Posts
