21 - 24 of 24 Posts
Discussion Starter · #21 ·
I believe these are relatively current part numbers.
Receiver: 10367164
Antenna: 15821861 - This is the separate XM antenna not the multi-band unit.
Cable: 10380504 / 10380505 - You may need a longer cable or an extention depending on where you place the antenna or if you install the multi-band unit for OnStar & XM.
Hex-Nut: 11560973 - For mounting the unit under the glove box.
Hope this helps,
Discussion Starter · #22 · (Edited)
By the way, I did find out that the XM receiver does have it's own Theft-Lock that will activate if you install a used unit in another vehicle.
Thanks for Info Jason. I went to a stereo dealer I have used in the past and they will put the kit in for $220.00 (Kit + Labor) and it is the same kit you gave me the part # for. I figure that is a pretty good deal since I couldn't find the kit on the internet for anything less than $300.00
Discussion Starter · #24 ·
If it is someone you trust to do a good job that is a very good deal, I'd say go for it.
21 - 24 of 24 Posts
