1 - 9 of 9 Posts
Ok so I will be getting new door speakers thats not the problem my tb has does not have bose but it does have the little tweeters in the top of dash or 3 1/2's whatever they are is there a way to bypass them or will I be stuck using them ?
I thought only the Bose vehicles had actual tweeters in there, but the grille is present in all vehicles. Have you pried up the dash trim to see if those are empty locations?
2004 chevy trailblazer_ls_ext
it doesnt matter if you want them then just take them out or dont hook them back up when you do your new wires
I've noticed that I lose the "highs" when someone sits in the passenger seat, because they're blocking the speaker with their leg.
What is the size for the dash speakers? I think I'd like to mount something in there for better sound.
CDT makes a tweeter setup specifically for this, and I'll probably make a bracket to fit them behind those grills.
will I have to take the whole dash out when I look through the windshield I can see a speaker not a tweeter and the bolts that hold it down it looks like a 3 1/2 to me and my radio does not say bose on it anywhere it's just a cd and tape player.
I'm thinking the dealership took the bose radio out and put a standard one in is that possible?
I think it would take a lot more than just switching radio's.
The Bose system sends a pre-amp signal to the back of the truck where the Bose 6 channel amp is. Then it gets distributed to the 6 speakers.
Look inside the door of your glove box. There's a list of codes. If UQA is there, you have the Bose Premium sound system. (here's a list of what all the codes are).
Someone said about 3 1/2's up there - so I bought some. It's going to take some cutting to get them in. But yes, it just looks like a small speaker. If you decide to get at them, part way up the front pillars there's a little cover - pull it out and remove the screw - then the pillars can be pulled off. Once they're off the dash can be pried up and off - just snaps in place. Just be gentle so you don't break the clips.
Thanks I will look at it tomorrow so if I want to run speakers up there Is the a build in crossover or will I have to buy one to run them along with all 4 door speakers?
2003 trailblazer_lt
same here, drove me nuts:crazy:
take at what you have look first, there is a significant difference between the bose/ non bose systems
1 - 9 of 9 Posts
