1 - 12 of 12 Posts
pics dont do it justice..taken in the pitch black garage with no flash on.. the 4th pic better depicts the true white color (but for some reason the first 3 pics look a little blue :confused:
2 white 4.7 flex strips above firewall (were previously in my mirror turns)
2 white straight modules mounted to the hood
All wiring ran under hoodliner
(just a note.. take off your hood liner at least once to clean out all the nasty crap that builds up in there!)
Woah.........its a frickin" light show......in da hood......:crackup:....sorry just had to do that........looking awesome Majestics!!
Northwest Chapter
Just curious... Did the 02's use a hood pin switch, or a mercury switch for the OEM hood light?
Its one that is inertia activated, think thats the best way to describe it. When you open the hood a ball (or similar) inside the light moves to the other side causing the circuit to complete and the light to come on. Downfall is it sticks often and you have to whack the dang thing to make it come on. This LED trick is much better, definitely doing it to the SS. That makes 101 things the SS needs done to it, geez,
1 - 12 of 12 Posts
