1 - 11 of 11 Posts
First you need to pop the hood. Your grille and chrome bar are held to your truck with clips. First VERY GENTLY!!! start pulling your grille untill you start popping those clips out. Keep an eye on your chrome bar, because it is clipped into the headlight. GENTLY pull on the chrome bar at the headlight untill the clips come off, then work your way over to the other headlight. The goal is to be take your time and be gentle untill you have all the clips released. Set your grille aside(be carefull not to scratch it). Each head light has two metal tabs on top of it, the outer tabs are slightly hidden in the fender. If you pull these tabs up, it will release the headlight from the frame of the truck(be carefull not to let the headlight fall out and scratch your bumper). Once you have the headlight assembly out, pop off the circle rubber cover on the back of the unit. Your bulbs will be inside there, and make sure you don't touch the bulb when removing it. Just reverse the process when your done changing your bulbs. Good luck.
2006 chevy trailblazer_ss_ls
Welcome to the site! If you'll take a moment to fill out your profile in the User CP, it will make it easier to answer questions and help everyone to get to know you and your ride better.:thumbsup:
BTW, you can just pull off the rubber cover on the back of the fixture and reach in.
1 - 11 of 11 Posts
