My wife's Envoy has been sluggish off and on for a couple of weeks, push on the pedal and not get the power expected. Then, yesterday she started it and pushed the pedal to the floor and the engine did not rev at all. She put it in park, turned it off, restarted, and it seemed to work.
I did a scan and found the P1515 code, which indicts the Thottle Position Sensor. One thing I noticed when I was playing with the pedal is that when the vehicle is idling in park, I can put the pedal to the floor and only get about 2500-3000 RPM. So there's clearly a disconnect.
I immediately read all the forums here, and tried removing and cleaning the throttle body with intake cleaner. It didn't look bad, but easy and free. That didn't have an effect.
I replaced the fan clutch a couple of years ago with supposedly the "new and improved" fan clutch, so that is not likely it.
So I spurged on a TPS, which unfortunately is built into the throttle body. I still can only get 2500-3000 RPM max.
I see there's a sensor at the pedal. I believe it's about $115 for the pedal/sensor assembly. That's probably next on my list.
But I'd like opinions as to whether it could be something else. I've not seen any other codes thrown (lately, anyway). It doesn't even throw the P1515 code very often. (I think it must have been that time where it did not rev at all.) But I'm concerned I'm chasing the wrong problem, as I've read that P1515 is usually accompanied with other codes.
Am I on the right track? Or should I look elsewhere? Opinions?
