1 - 7 of 7 Posts
chevy trailblazer_ls
Any ideas?
I have an 02 Trailblazer. The motor is extremely rough almost to the point of dying when the AC is on and at idle. Like at a red light.
Turn the AC off, no problem. Turn the AC on, it lowers the RPM to 400RPM and starts to die. The AC works great. I get 19 MPG on the highway. It doesn't miss any other times?
What could it be? Coil? If so, how do I test it with an OHM meter? I don't have a scanner.
Thanks
what you describe- is a classic symptom of a dirty throttle body- and a recent battery disconnect.
Thanks for the quick replies. It's been missing at idle for a long time now. Just now looking in to it. The batt died today and I replaced it. Figured I would try to figure out the miss while I was at it.
So yes the batt was disconnected but it's not the issue. I'll try the clean TB trick now. Thanks.
Just performed the TB cleaning. It was pretty dirty. 101k miles.
It seems a little better but there is still a noticeable stumble when the AC is on. High/Low RPM and them a stumble.
Maybe it will get better after the computer learns it again.
1 - 7 of 7 Posts
