1 - 8 of 8 Posts
I need some help. I want to install an SLR performance chip on my 2006 envoy denali xl. I need to know what wires are for the IAT sensor on the MAF. Can anyone help with this. There are 5 wire to the harness and they are yellow,pink,grey,and black.
· Northwest Chapter
OK, those wires are located inside your garbage can. That should get you on the correct path.
Seriously man, take 5 mins and search through the forums to see how bad even Jet chips are let alone the $5 resistors you buy off ebay claiming +25hp and 5mpg, they are BS. Return the chip and buy a real tune, then you will get power and mileage.
Thanks for the reply. I will heed your advise. Any other good ideas to do in conjunction with the PCM tune? Airaide throttle body extension or just stick with the pcm tune? I'm just looking for a couple of MPG's (3-4).
1 - 8 of 8 Posts
