With a 2/4 drop kit will 255/70/16's fit without rubbing? I believe they will since they are almost the same size as SS 255/50/20's.
I have the GF setup 1.3F/3R and running 245/75/16 and no rubbing whatsoever........maybe someone else will be chime in as well to help you out!
Yeah man, i have the belltech 2/3 and im riding 275/30/24 and i only rub on a full lock turn. So you shouldnt have any issuse at all man. You might look into an adjustable panhard par to center your rear axle after the drop. Just check in out, sometimes when you drop TB the rear axle shifts to the right and the panhard bar will center it for you..
