1 - 16 of 16 Posts
2003 gmc envoy_slt_xl
okay- so I tackled the shocks and struts on the Envoy but the passenger side lower shock mounting bolt is cross-threaded. Anyone got ideas on how to resolve it? I've tried a new nut, but the thread won't grab enough to get started. I can't find a m-16 die for nothin either! Any suggestions?
It probably goes without saying but I'll say it anyway. Make sure you use the proper thread pitch when using a thread file and file in one direction only, away from you, don't use it like your sawing wood.:nono:
2004 non_gmt360 other
Do you have a Dremel or another motorized tool like that ? When I have issues with threads I use a thin cut blade (like a grinder) and carefully shave the threads till it's straight again.
Might be Cheaper/easier just to pick up a new bolt and nut.
it's the huge lower bolt that the yoke bolts to. It's pressed in the lower control arm, sadly, and is not servicable. Sadly.
it's the huge lower bolt that the oke bolts to. It's pressed in the lower control arm, sadly, and is not servicable. Sadly.
Wow, I assumed that they were the same as the TB. We have a ford van at work that has the same crappy setup for the front shocks and the control arms. One of those bolts broke when I was changing the shocks on the van so I welded a washer to what was left of the bolt after installing the new shock.
Had to cost GMC more $ to make them like that.
Back to my first sugestion then.
1 - 16 of 16 Posts
