I have a 2006 and my issues are similar to several others but still unique. My wife informs me that when she was sitting at a stop light she says the engine acts like its going to die and the lights dim. So I drive it a cpl days and nothing. I took it to Auto Zone to see if any Engine codes were stored and "no codes". Finally it happened for me. I was sitting still and the engine RPM's dropped to 3-400. The lights dimmed. The Voltage gage showed 9.5 -10. The motor was NOT missing. It was running smooth. Weird.
I have a new battery installed. I put a voltage meter on the battery and was messing around turning things on and off... The normal reading with low "draw" was 13.9 - 14.1. I then turned EVERYTHING on I could and the idle dropped low again. The test reading was all over the place. Constantly moving from 13.75, 3, 10, 0.22, 5, etc. It bounced all over. So I thought alternator. So I went back to Auto Zone and had them run Diagnostic. The Alternator passed all tests. Weird
Now I am confused. I have no issues if I am just running "normally". Lights, radio, and heat on low ( 1 or 2) however if I turn on the heat or defrost to 4 or 5 when idle ling at light then it will drop down again and act like it wants to die.
I don't have the money to throw parts at it. I am not trying to lead anyone to say it was the alternator... but I'm open to suggestions.
BTW My TB has the same whine as the rest. Mine sounds like it is on the right side... I'm again thinking alternator...Yes the whine is RPM controlled.
Pep Boys says they will test the alternator for free if I take it off, but want $25 to test it on. It doesn't seem that easy to take off. I have basic to moderate skills.
Does this sound like anything to the Masters on here?
Mileage is at 110K if that matters. Battery is less than 2 wks old. Just replaced original battery due to cold temps.
