1 - 10 of 10 Posts
2004 gmc envoy_sle
i'm new to the forum, and new to owning an envoy. my previous vehicle's low fuel light would come on when my 20 gallon tank had run dry, but there was a 5 gallon reserve, which could keep me going for a while.
when my fuel light comes on, how much more fuel is still in the tank?
i have a 4.2L, envoy sle.
thanks for any help.
2004 gmc envoy_sle
10-4 guys, i do alot of commuting with intervals of highway that can go for a while without gas stations. all i needed was a better idea of the fuel light. thanks for your help.
2009 gmc envoy_sle
since we're on the topic of the low fuel light, when exactly would the light turn on? before refueling I had the needle at 1 to 2 lines away from E and didn't see the light come on compared to other cars' low fuel lights turning on b/w 1/4 and E. Does the sensor vary in each car or does the needle have to be exactly on E for the low fuel light to turn on?
i usually don't let the level run that low and refuel around 1/4 or slightly below 1/4 but was running a bit late for work today and didn't have a chance to refuel near work
2005 chevy
I haven't let mine run dry yet, but I can tell you that it will get pretty low before the light comes on. In my EXT, it gets between the E and the next line up. And as previously stated, when I fill up, I put in about 23 gallons (tank holds 25)
2005 chevy trailblazer_ls_ext
:iagree: Same here. I have the EXT also and I've only seen my low fuel light come on a handful of times in 4 1/2 years, but like blckshdw I would put in about 23 gallons or so when it did come on.
I was curious about this a while back, and got gas as soon as I could after the light went on (18 Gal tank). It took 15 1/2 gal. About 16% left.
1 - 10 of 10 Posts
