Location of grommets?
2006 Views 3 Replies 2 Participants Last post by  djthumper
I am currently trying to install a simple train horn. However the wires must run all the way from the trunk to the battery. I know of the grommet next to the gas pedal and I will use that for install my switches. However I can't find a grommet in the rear of the car to get the wires from under the car into the interior and then run them up the side foot panels. is there even a grommet in the back ? If not what's a solution?
Why can't you run it through the frame and then into the firewall?
Where's the opening to run it through the frame?
Look at the left frame rail There are a few holes in the frame. You may have to feed it through the ends and then fish it through the other holes.
