Voltage Regulator
It seems GM does not want fess up to a on going problem with voltage regulator's. They are integrated in to the Alternator and don't adjust quickly enough went voltage demands change, like when a air pump turns on. This effects lots GM models and they have no urge to fix it as long as it doesn't effect safety. The regulator adjusts gradually instead of instantly causing the lights to flicker or voltage to drop. So all of you with Bad Ass stereo's are getting the worse of this.
