The liftgate on my 2009 trailblazer was getting extremely hard to open so I examined the mechanism and it was a little rusted so I shot some PB Blaster on it which did the trick for about 4 days and then the damn thing won't stay latched. If I hit a bump or pass a semi the lift gate will open enough to set off the open door alarm and turn on the interior lights. I can shut the lift gate, here the electronics showing it engaged but can then grab the bottom of the lift gate and open it without using the handle to disengage the latch.
I then opened the lift gate and manually pushed the latch closed and heard the electronic click showing the latch engaged but could then pull the latch open without using the handle.
I have the cover off the lift gate and have looked at the latch mechanism and the handle linkage but can't see what would cause this problem. One thing of note if it makes a difference, there is linkage that attaches in the latch mechanism area which controls the opening of the glass of the lift gate. It keeps turning so that when the button is depressed on the window it doesn't hit the linkage and open the glass. Not sure if it's related to my latch issue but thought I should mention it in case it jogs someone's memory.
