Does anyone have a diagram of changing the front wheel barrings? I am almost positive mine is going out.. theres a hard grind not loud..i can feel it though.. Any help would be deeply appreciated!!
thanks again
If the noise gets louder when you turn right and quieter when you turn left, then that does sound like the left bearing is going. You will need a 35mm, IIRC, socket for the center axle nut. The torque for the axle nut is 103 ft.lbs. The torque for the wheel hub and bearing assembly is 77 ft.lbs. The ABS sensor bolt is 13 ft.lbs. Sorry, I don't have a way to show the diagram.
2007 chevy trailblazer_lt
Jack up that wheel. Grabbing the top and bottom of the tire, give it a shake up and down. If it moves or clunks, its either a bad hub/bearing or a ball joint. Or a really bad tie rod end....helps to have a second set of eyes.
