I put in my LED's today and put the first one in it lit up fine put the second one in and blew 2 fuses. I took it out switched it around replaced the fuse and it popped again. Any suggestions.?
If the lights were off when you installed it and it blew fuses, then
you've got a bad LED.
If the domes were powered/lit when you swapped it out, thats the issue.
Thanks I figured it out today. The LED was bad. I replaced the fuses and everything worked fine once I took the Bad one out. I ordered a LED for the glove box and I just relized there is no light in there. Oh well I will just have an extra floating around. LOL Thanks for all the help.
