1 - 6 of 6 Posts
My 2007 Trailblazer will not work after a cold night! I have checked fuses 3 and 19 and they are clean. I have checked the wiring in the boot between the liftgate and the body and see no breaks! I have not checked or found a wiring harness connector between the gate and the body. If I remove the negative terminal from the battery on a cold engine the system responds immediately and the programming mode works fine too! I would like to check connections on the Lift Gate module but do not know where it is located too. This is making me crazy as I can only guess that the cold is breaking a connection somewhere. Please Help! Many thanks in advance for your help. Bob T
1 - 6 of 6 Posts
