2002 tb ignition switch will not turn back all the way. I can pull the key out at start. And while car is crunk. Meaning i dont need a key to crank. It just happened all of a sudden
Replace the ignition LOCK --- not the switch.
This is a mechanical problem, and although you MAY have a concurrent electrical problem, start here.
  1. Solved. Its just the cover on the steering wheel. I believe an inside piece of the cover broke off. When its completely closed, The cylinder where the arrows were pushes up. I used paper and tape to fix the problem.
