I dont shop on amazon and havent used my key fob in probably 5 years. I would like use it again. I dont know if my rear liftgate module is bad or if I need a new remote ?
you can pull the pass through connection to the liftgate there is usually broken wires inside that. i had the power rubbing right on the ground in there. check that before you buy a module. then check the rest of the connectoins for corrosion if that doesn't fix it. if you find a damaged wire might as well fix all of them in the boot because sometimes they break inside the insulation.I dont shop on amazon and havent used my key fob in probably 5 years. I would like use it again. I dont know if my rear liftgate module is bad or if I need a new remote ?
Would the dealer have a remote for it ?you can pull the pass through connection to the liftgate there is usually broken wires inside that. i had the power rubbing right on the ground in there. check that before you buy a module. then check the rest of the connectoins for corrosion if that doesn't fix it. if you find a damaged wire might as well fix all of them in the boot because sometimes they break inside the insulation.
yes. the dealership or any parts store. probably even wallmart. rock auto had them for a bit less but everywhere else besides the one place charged just under $100 for one FOB. the dealership may want to charge you to program it also.Would the dealer have a remote for it ?
Im gonna look into it. I would like to start using a remote again.yes. the dealership or any parts store. probably even wallmart. rock auto had them for a bit less but everywhere else besides the one place charged just under $100 for one FOB. the dealership may want to charge you to program it also.
I've bought a couple of fobs from Amazon ... they work well and have very good range. I'm satisfied.I dont shop on amazon and havent used my key fob in probably 5 years. I would like use it again. I dont know if my rear liftgate module is bad or if I need a new remote ?
Yes they do.Would the dealer have a remote for it ?
A few years ago I put new batterys in it and it didnt work and I tried another remote and that didnt work. So I have no idea. I was reading it might be the lift gate module but never check thatPPS ... have you tried to program the fob?
It's easy... even a dealership lotboy can do it.
Oh cool thanks for posting this. I love ebay and have been shopping on it for years. Ill check it outI've bought key fobs for several vehicles from this place (an ebay seller)
Security Measure
www.ebay.com
The quality of the remotes is fantastic, they work perfectly, the price is right, shipping is fast, and they come with vehicle specific instructions.
Yea thanks. So how do I check the liftgate control module ? Should I just start with getting a new remote ?You are welcome. The key fobs I purchased from them 6 plus years ago are still working perfectly!
Thanks ill do that.I would go ahead and do what Mr. Sparky recommended in post #3 - inspect the wiring, while you wait for the new key fobs.
im not sure if i can post this actual address but the company i purchased from is remotesremotes.com and it was ten or eleven bucks per FOB. look identical to the stock FOBs.Thanks ill do that.
I dont think I even have the remotes anymoreLook on the back of the remote, there is a GM #, the #1 ends with 008..#2 ends, 009, this is the # you need to match, mine came with simple instructions.(even a caveman can do it)
Got mine off Ebay, about $20
