Hey guys!
I looked through the threads but couldn't seem to find my exact issue.
I have an 02 Chevy Trailblazer LS.
I tried to program the key fob when I first got it and it wouldn't work, neither did the rear windshield wiper/fluid & the back window and hatch wouldn't lock. so I did a bunch of research and found out it could either mgr the Lock Gate Module or wires in the boot when you open the hatch. I began testing, etc and finally found that the black wrote in the boot was severed, so I spliced it back together and everything works great. The key fob programmed and was done for about two weeks.
I noticed it started acting up not unlocking our living unless I was near the front of the TB.
Now it's not working at all, I cleaned everything with a q-tip and alcohol, tried new batteries, everything I could think of, to no avail.
It's not the wire acting up because the windshield wiper in the back and the hatch still lock.
When I use the directions to program the remote, the trailblazer hours into programming mode, beeps does its unlock lock thing, then I hold the unlock/lock button on the key fob simultaneously, after 15 seconds it locks and unlocks letting me know it's programmed, I then take the TB out of programming mode by turning the key. I take the key out and exit the truck to test the key fob abs nothing!!
So aggravating! What do I do? Has anyone else had this problem? Please advise!
Thanks!
Sara:duh:
Thanks!
Sara:duh:
