1 - 12 of 12 Posts
today i was going down the street and i floored it about 30mph to 35mph then let off about 45mph to 50mph and let off the accelorater and it kept going i have no clue why any help.
btw i had to turn off the car to make it stop.
Thanks
Dunno why, but this is why I HATE drive-by-wire. Nothing wrong with cables in the past, why add an extra link that can go bad. Cables don't automatically open the throttle, your foot does..imagine being in a parking lot with kids and something freak happens. How many reported cases.....prolly few at most but who wants to be the one?
We have the technology to make accel cables smoth as butter with little resistance. IAC motors and stepper solenoids are much safer.
Check my sig for how to clean your throttle body. At any rate, even if it isn't dirty, you can check for full range of motion on the butterfly valve AS LONG AS IT IS UNPLUGGED and out of the vehicle as a general rule too. The drive by wire is a pain in the ass if anything goes wrong because it is near impossible to nail the problem without checking things manually.
Let us know if you find anything!
Good Luck,
Keith
I'd guess stickiness in the accelerator pedal as a secondary possibility. There are redundant potentiometers on the pedal plus redundancy on the butterfly valve. Eliminating the cable means the PCM can run the cruise control with software only, plus emissions are easier to control under what used to be a difficult condition of when you let up off the pedal while cruising. The PCM can keep the RPMs up so the intake vacuum doesn't plummet.
2002 olds bravada
:iagree: i'm also thinking badd APP sensor?
That's why there's two APP sensors - to prevent a single failure from causing full throttle runaway. And if the two sensors fail to agree, it doesn't average them together or choose one over the other, it goes into REP (reduced engine power) mode and all you get to do is limp to the side of the road.
2004 chevy
This might be too stupid or simple but have you verified that your cruise control is off? When I first encountered the cruise controls on the turn-signal lever back in my '91 chevy pickup I used to accidentally turn it on once in a while, and the truck would race to get up to speed seemingly out of my control.
I've since gotten used to regularly checking that I didn't bump the switch. :D
2004 trailblazer_lt
Thanks
Did the accelerator pedal stay on the floor when you lifted, or did it return as normal?
im pretty sure the pedal is off the floor becuz it was not straigh accelerating and i hit the brake to slow down after it first went on then did it again so the cruise was off
mine isnt drive by wire :undecided
iIRC its all electronic...the pcm "guesses" how far yur throttle pedal is depressed and thats how far the butterfly opens up...i kno wen im under my hood i can only rev by pressing the gas pedal...no opeing the throttle within arms reach :no:
Umm. That is drive by wire. Electric wire not cable.
1 - 12 of 12 Posts
