1 - 13 of 13 Posts
I've been looking for a new pair of front speakers for my 2002 Envoy. I already have an aftermarket headunit installed (Clarion FB275BT). All I want is crystal clear mids and highs with blended bass.
The Infinity Kappa 62.9i speakers caught my eye- but Crutchfield claims they won't fit. Are they too deep? Mounting holes won't line up? Or is it just an error on their part?
There's also a shallow 62.9is available but I'd prefer the fullsize ones if they'll work with minimal/no modification.
Will these fit or should I look elsewhere?
Thanks!
Edit: There's a nonremovable crossover box. Could that be the issue?
do you have bose? otherwise you should be looking at 6.5's
i had the kappa comps, the midbass was "ok" and the tweeats weare a bit harsh. IMO.
Interesting. 2 votes down for the Infinity speakers- I'll look elsewhere then. JL Audio's products do look good.
I thankfully don't have Bose junk in my car. "Better profits through marketing". :D
Discussion Starter · #7 · (Edited)
No, no amping at this point. Too much for my budget.
Edit: Do the JL Audio C2-650X speakers do well unamped or am I better off getting something easier to drive? Crutchfield claims they don't fit but I'm not so sure I trust their guidelines.
2007 gmc envoy_sle
Yes, the C2's will be fine off of just your headunit. I wouldnt go off of their guidelines either. If you honestly had any trouble getting them in, im sure a local car audio installer could help you out. I have two sets of XR components in mine, and im sure those are deeper and i had no issues putting them in.
Thanks everyone for your suggestions. I'll probably go with the JL Coaxials over a component set since I want to try to keep everything reversible. The idea is to put the old system back in when I trade this car off down the road which could be a problem if I cut out the existing tweeters.
I've read that the tweeters in the front would need to be cut out, which isn't reversible and therefore not something I'd want to do. I went ahead and bought a set of the JL Audio C2 coaxes. I can always resell them if I change my mind in the future and want comps instead.
I don't see a factory tweeter location other than in the doors next to the woofers. Different trim maybe?
2003 trailblazer_lt
ca glue reverses everything:woot:
the bose system has them in the top of the dash instead of the door, some people without bose have used that spot for aftermarket tweets
1 - 13 of 13 Posts
