1 - 17 of 17 Posts
2007 chevy trailblazer_lt
Need some help. Just installed my new K&N Filter tonight. Everything went OK on the install, but now the engine light is on. No I haven't been somewhere to get the code ran. I work 3rd shift so I was so exicted that I put the new one in a test drove it. Everything looked good. Get up about 4 hours later. On the way to work the engine light comes on. I disconnect the battery for about 30 mins it goes away. Then when I drive it around for a bit it comes back on. Any help would be great.
Got a good deal on it from ebay. $225.00/new free shipping. :woohoo:
http://cgi.ebay.com/ebaymotors/ws/e...0020871131&sspagename=STRK:MEWNX:IT&viewitem=
The only reason for it to throw a code would be if the installation was done incorrectly. Other than checking your work, the only thing you can do is read the code before we can help.
2007 gmc
If disconnecting the battery and resetting the PCM did not work for you then you probably need to get a tune to calibrate the MAF sensor for the new airflows. Would double check the install.
Here are the errors I'm getting.
P0101
P0102
they told me to replace the MAF sensor...I only have 30k.
Basic Vendor- Skid Plates
You didn't drop or otherwise [email protected] the MAF sensor when you had it out, did you? It still has the factory MAF "screen" on it, right?
For the record, you do not need a tune for a K&N intake, especially with a MAF system (sometimes do with a speed-density system, because it calculates expected airflow, instead of a MAF that actually measures it)
Mike
2007 gmc
Maybe the 355s are a little different. Had a few that would continue to throw code with a K&N CAI. After the tune the codes were gone. By all means, check the install and the MAF sensor for proper installation and function. Maybe clean the MAF sensor???
maybe you have a leak......unplug the negative on the battery,,,,,retorque(hand tight) all the clamps...including the MAF sensor where it is located and go from there......good luck and let us know how everything goes
OK here it goes. Rechecked all of my connections. Everything is good and tight. Disconnected battery to reset everything again. That didn't work. Reinstalled factory ran with no issues. Reinstalled K&N. Engine light on again. I do have a question though.
1. After putting the K&N back in. Reconnecting the battery and MAF sensor. The truck doesn't want to stay running. I have to keep restarting the truck about 10 times to get it to run. Is that common?
Western Canada Chapter
2003
It might be your throttle body being a bit dirty. Not sure what kind of gas you have been running but it may need a cleaning if it does not want to idle. It will eventually learn it's way out of the problem area but the cleaning is the best step.
The other scenario is that the MAF is not seated in you K&N properly and that is the sole root to your problem. Especially if it only stumbles with the K&N installed :m2:
Fixed MAF sensor was in upside down. :bonk: Didn't read the instruction.
You probobly got the MAF filter dirty from the new filter oil
I just wanna say thanks for all the help. I would recommend this to anyone.
Yes I clean the MAF before I reinstalled it. :bonk: Just make sure the little hole goes towards the filter....:bonk:
I have the same K&N also and love it, I could have found it a little cheaper on ebay, but I wanted a valid warranty so I got it at here. K&N 63-3062, or you can try one of the vendors on the forum here, you can usually find a good deal that way as well. This was very easy to install and I love it. good luck :thumbsup::thumbsup:
2008 chevy trailblazer_ls
I have an 08 and im ordering the K&N in the morning. Was hoping you could post a pic or 2 so i could see what to expect. Thanks
1 - 17 of 17 Posts
