2006 chevy trailblazer_lt_ext
as the title states just got a nice v8 ext 4x and i am looking to lower it for my wife (at first i was going to raise it but i hear that the ext has trouble wanting to swap ends as it is ) it looks like the eibach is the only company that makes a kit for , anyone have a 4x v8 ext that has used this kit. also my sister has an extra set of ss rims that i can use anyone know if the will work with this setup thanks in advance -m
2009 chevy
Hi, don't know the source of your rumour, but I have been driving a LWB truck for 3 years and, have not had any problems with stability. In fact, physics would dictate that a longer wheel base should be more stable.
The only "switching" problems that I have had (and this is common on any vehicle with a locker or posi rear end) is a tenancy to loose lateral stability on an icy surface. Putting it into 4 hi will solve this problem.
2006 chevy trailblazer_ls_ext
Lifted ext
I just lifted my ext and its great! Check back and i will post picks. I put a 2.5" lift in the front and it looks fantastic!
Northwest Chapter
For lowering, you can use Eibach, Ground Force, Belltech, or stock SS parts. If you use SS stuff, get the front springs and all 4 SS Bilsteins then use a set of GF 2" rear drop springs. Probably the best ride out there, the stock SS rides very smooth while being not being too stiff.
i got the eibach kit like 1.3front 2rear lower anybody have a how to on install
