1 - 6 of 6 Posts
2006 gmc envoy_slt
In a rush today my battery died, and I hooked up my jumper cables to the positve and neg. cables leading into the fuse relay box under the hood. After do thing I disconnected them and hooked them up to the battery. I was able to get the car running, but I have no power to my windows, locks, radio, climate control its just dead. I've checked the actual fuses in that box and the one under the rear seat but I can find any tripped ones. Did I fry something major or could there be a hidden fuse I dont see. Things like hadlights, turn signals and windshild washers work. Its an 06 Envoy SLT, thanks for any help guys.
chevy
Sounds like you blew the mega fuse on the front fuse box. Do a search for it mega fuse on here, should be plenty of threads covering it. good luck!:cool:
:iagree:
Even though those cables leading out of the fuse block are Red & Black, they are both positive cables. Definitely a blown Mega fuse.
2006 gmc envoy_slt
Thanks guys, I finally got the right combo of keywords and found those threads on the megafuse. One more question PEPBoys only had a 150 and not a 125, does anyone if my dealership would carry the 125. I know its probably not too big of a deal but in my head they put the 125 on there for a reason.
I'm sure you can put the 125 on there till you get the one you need. I paid $14 at the dealer when I needed to replace mine a while, on my old LT.
I had a 175 on there from AutoZone after mine blew because it happened over the weekend and my parts dept was closed.
if you jump it wrong again, the 150 should blow just about as easy as the 125 :)
1 - 6 of 6 Posts
