1 - 11 of 11 Posts
Swapping the stock tranny on the SS 2WD with a T56? Anyone did this before with the 5.3?
Max GVW, according to TTC for a T56 is 3,968 lbs... a TBs curb weight is roughly 4500 lbs...
But a little ingenuity, and I guess anythings possible :)
So you are saying the T56 wont handle the weight? SRT10's are running them with no problems and they weigh more.
From what I've read... they run a modified version of the T56.
Discussion Starter #5
They have a larger spline i think 33 compared to 28 or something like that. They also come with steel forks and carbon synchs. I dont know if we can have the larger spline, but i know for a fact that we can swap in the steel forks and synchs.
Discussion Starter #8
2006 chevy
would need an aftermarket LS2 engine management like MOTEC.... not that that is a bad thing...
and i would bet a new driveshaft...
driver floorboard doesnt look to be clutch pedal friendly cause there was never a TB with a manual
but anything is possible
Discussion Starter #10
Isnt the LS2 PCM the same as an Auto LS2 GTO? If yes then EFI V2 should control the LS2 PCM on the TBSS or just put a manual GTO LS2 tune in it. Im sure DS is needed. So i get that there is no one who did this before.
2006 chevy
Uh no the tuning side of it is DEFINATELY not that easy lol.. But I'm relatively sure the trans will fit, however I believe the shifter would end up right in the back of the console.. not exactly optimal placement..
1 - 11 of 11 Posts
