I saved my old coils and they worked fine before I swapped so I will rule them out by swapping with them.![]()
That connector is in the same harness as the coil connectors...right? I'm thinking that's the main disconnect for the coils. You could verify wire colors compared to the wires on the connectors that plug into the coils.
Forget "code readers". Codes can be helpful, but the real information is in the data stream. A REAL scan tool is needed.
Determine the misfire history (misfire counts) of each individual cylinder. This is not a "code", this is the number of misfires over time, per cylinder. "0" is a good number, anything more than one or two should get your attention. Hundreds or thousands is "bad news". When you know which is the problem cylinder(s), you can swap coils to see if the miss moves to another cylinder. If so, the coil is weak and getting worse. Could also be fuel injector, or an engine mechanical problem (burn valve, low compression, etc.) but my first guess is failing coil. When the engine is under load, the coil can't supply enough voltage to fire the plug reliably.
Yes, that connector that im pointing to leads into the bundle of coil wires. Would a frayed wire in that harness potentially cause a short that would cause this to happen?
