1 - 6 of 6 Posts
Can anyone help confirm if these type of bulbs are the ones we have in the door lock and window switches in our TB's I could have sworn these were like the ones i saw when I had the switches apart.
NeoWedge series LED Lamp
T1-1/4 NeoWedge base LED bulb for indication lamp applications
Lamps consists of non-removable standard LED or High Power SMD LED
3mm LED in NEO3 lamp - 4mm LED in NEO4 lamp - 5mm LED in NEO5 lamp
12 Volt DC - 100/120 degree beam pattern
Available in White Blue Green Red Amber
http://superbrightleds.com/instrument.html
and if they are which ones would I use, 3, 4, 5?
the Neowedge bulbs are in the front door switches only
the rear window switches are soldered on..
but it really does no good to put Neowedge LEDs in the front switches because the design on the inside sucks and its alot better to solder about 6 LEDs spread out on the drivers side and 3 on the passenger side.
as far as the neowedge bulbs go any idea's what size the 3mm, 4mm, or 5mm for the front doors if i were to go that way? or will they all fit
yes they are a pain ive been wanting to do this but not sure if i have the right size leds what size did you happen to use for yours???:thumbsup:
1 - 6 of 6 Posts
