1 - 7 of 7 Posts
Hey new to the site and I have to say so far its been very helpful.
I am installing an amp and speaker in the back of my 02 TB, I was wondering for any of you out there who have installed amps, for the power cable do i have to go through the fire wall or can i hook up somewhere else? like the back seat fuse box? also where is the remote wire coming out of the back of a stock radio? if not then where should i connect one to? Looked at someones pic of a wire going into the fuse spot for the front wipers in the fuse box under the seat. is this an ok idea? what gauge wire do i need?
Thanks
installing a small 250 amp with a 10" sub if that makes a dif in anything.
2003 trailblazer_lt
Battery is recommended.
Does not exist.
Has worked for others for remote turn on.
Can you be more specific? Power lead or remote lead?
Thanks. for your last response: what gauge wire do i need for the remote wire. Also where would be the best place to go through the fire wall for the power supply?
There is a sticky in this section that shows a good place to run the power wire through dash. It is the method I will be using. It is labeled my version of amp install. I think its the first sticky.
2005 buick rainier
Remote wire doesn't need much - I used 18ga and it works fine. I put the 4ga power cable through the firewall by cutting a hole in the large rubber gasket to the left of the steering column. Be careful, as there are already wires running in there!
Discussion Starter #7
Thanks! ill try that out and let you know how it goes. Ill post some pics
1 - 7 of 7 Posts
