1 - 3 of 3 Posts
I installed a new head unit today. I go out to start my truck to leave and my radio is on and I cannot start the truck. When I try to crank it I get an unknown driver on the instrument panel and nothing happens.
Earlier today after installing the unit I was going to a restaurant, made a right turn and all of the instrument panel lights and gauges went off and on. I believe the lights on the thermostat went off and on. I'm preempt sure the headlights flickered as well.
I know that I did not tighten the negative terminal on the battery as tight as it was when I took it off. I tightened the negative terminal and tried again and no luck.
As I'm typing this I have the negative terminal unhooked. I am going to try and see if I can reset anything.
Discussion Starter · #2 ·
unhooking the negative terminal and letting it sit for about a half hour did the trick for now...
If the radio was on, when you went to the truck, then your key was on, as well?
If key was on, then it may be a security issue that is preventing your T.B. from starting.
Here is a procedure to correct the no start, IF THE SECURITY IS THE CULPRIT.
http://forums.trailvoy.com/showpost.php?p=276533&postcount=24
1 - 3 of 3 Posts
