Hello. Have read thru a 100 IS posts but have yet to read any with same issue. So I replaced the ignition switch on my 06 TB EXT. because all the lights on the dash would stay on after it started. Thought maybe starter was staying engaged. So after I replaced the IS the truck starts in the run position. Fooled with this every way possible. I bought a 07 with a seized motor. So I swapped steering column and still same thing. Swapped fuse box under the hood then the BCM same thing. So I pulled the crank fuse and the truck still starts in the run position. Any thoughts? Thank you.
