I'll look for some of that Kroll, but I don't know if I can buy it locally.
I got the jamb nut loose but the tie rod itself is stuck.
I used some heat from a Mapp gas torch and I made a coupling from a big nut & bolt to couple the box end of 2 combination wrenches together for leverage. I used a grinder on each face of a 15/16 bolt head until it would fit the 22mm wrench, tightened the nut & bolt together, then put a 15/16 wrench on the nut. I heated it a couple times before the nut let go.
I'm thinking of moving on to the struts & control arms. The tie rad that's, for sure, bad is on the other side.
The way I have this thing on the rack with the safety stand from the floor on one side, it's not easy to get at the steering wheel to extend the rack out to either side to access the inner tie rods. The Chiltons online, that I have access to through the public library, wants you to hold the rack with a pipe wrench on the valve side when removing either side inner tie rod. They actually show it being done with the rack removed from the car.
