Heat Blend Door Actuator & Rear Aux Actuator-correct parts?
I've read all the posts on this section, and just want to make sure I get the correct parts. I have a 2004 TB EXT LT with the digital climate control, and there are three issues:
1. It's winter now, and the front passenger side has plenty of heat, but the driver's side blows cold. All the modes work correctly for blowing air (dash, floor, and defrost), but we only get heat on right side (passenger), and no heat (cold) on left (driver). I think I have pinpointed that problem to the Blend door/temp actuator for the Drivers side, ACDELCO 1573598 {#89018676} (RockAuto has it for $34.99)
2. I also hear a clicking noise from the REAR passenger side of the vehicle (at the very back of the vehicle near the rear hatch). This was a noise I heard earlier, then is stopped, but when I went through the process of trying to reset the calibration (pull the fuse, don't touch controls for 90 seconds, etc and thank you all for those instructions) the clicking sound came back while recalibrating. I've pinpointed this to be the Rear Auxiliary actuator (probably missing gear teeth). I'm pretty sure this part is ACDELCO 1572811 {#88892975} RockAuto has this part for $46.79. (sorry, I can't post the links, since I haven't reached my 5 post limit yet)
3. Only unheated air comes from the roof vents. I THINK maybe that these are also controlled by the blend door actuator, but I'm not sure - or maybe the rear one - or is this another problem? Does anyone know?
I've been reading the threads on Trailvoy ever since we got our first TB (used in 2008), and you all are a FONT of knowledge. Because of the forums, we've been able to deduce (and fix) the problem with our A/C and stalling - to needing to clean the Throttle Body; we've been able to replace the Window arm regulator; diagnose and repair the shift arm controller; the upper ball joint, and more! I can't thank you all enough. I think I've only posted once, but read quite a bit. So, if anyone can chime in to verify the parts for 1 and 2, and have any information for 3, I would greatly appreciate it!
My husband and both work on the vehicle, but I do all the online research (he's mechanically savvy, but not computer savvy). He's got a code reader, if that will help diagnose the problem. We used to have a 2004 TB EXT LS (more basic model) but someone rear-ended us and it got totaled last year. Insurance covered a full replacement - same year, almost the same mileage (135,000), but a higher-end model with the digital climate control (LT). We do all the repairs ourselves, and keep it running smoothly. He likes the Chevy to work on much better than our old Ford, and this forum has been a God-send!
