2002 Envoy.
I just replaced the air door actuator that switches between defrost and floor due to no floor air.
I put in a Dorman 604-115
I Installed the new actuator and did the fuse pull reset.
I watched the actuator go to Floor, then defrost where it stays. I can do the reset again and it alway does the same thing.
so that air Door actuator was not the problem.
I cannot select floor heat at the control even though it obviously can do it.
I’m thinking a new controller is the answer. Any other options?
I see used ones on eBay or new from Dorman.
suggestions?
Thanks.
suggestions?
Thanks.
