Having an issue with the AC on a 2003 Envoy. The HVAC control unit randomly shows different outside temps, only some of which are remotely correct. I have performed the three button calibration numerous times to get the problem to go away without luck. Now, the real confusing problem. When the exterior temp is displaying lower than true temp (32 degrees on a 75 degree day for example) the AC will not kick on. Once the outside temp starts to display normal temps the AC begin to work.
Has anyone had similar issues? Do you think it is the outside temp sensor or a need to reprogram the HVAC controls? Any input would be appreciated. The outside sensor seems easy to replace but I do not want to go that route if it will not fix the problem. Thanks.
