1 - 8 of 8 Posts
How do you turn off the front passenger side air bag. also, sometimes when is start my 2002 trailblazer i hear a clicking sound that sound like it has something to do with the airconditioner. What could be causing that sound
there is no way to turn the Pass. Airbag off.. short of unplugging it which I would strongly advise you not to do :no:
There was no switch in 2002. It was only mandated by a later regulation - 2005 IIRC.
Clicking could be an actuator. Does the HVAC system work OK otherwise?
Could also be dash gauges. We could start a fuse-pulling set of experiments to home in on the culprit. My buddy Rayvoy might have to help for the next 24 hours or so while I'm on a road trip.
2003 chevy trailblazer_ltz
I was kind of actually wondering about this myself...since sometimes the kids sit in the front seat...rarely. In the Silverado we can turn it on/off & personally I don't want to get smashed in the face! :O) So I turn it off!
yes the ac works fine just the clicking noise for a few seconds at start up. thanks for the help on the air bag. i have been looking everywhere.
2002 chevy
there should be airbag connectors on each front doors right into the dash, color yellow, similar to the one below your seat. Remove those (4) connectors and see if it works. If not you might have to get your BCM reflashed with a vin that does NOT have "Side" airbags.
I cant test it out yet since its at the dealer but ill check out this weekend and see if this will work.
2004 non_gmt360 other
When a vehicle first starts, the computer runs sensor checks throughout the vehicle. Makes clicking noises. Maybe that is what you're hearing ?
search for 'mode door actuator'
Many people replace it to get the clicking fixed. I tried that and still had the clicking. I am a firm believer that the actuator gets 'lost' so if you follow the reset procedure then that should fix it unless gears are stripped.
Let me ask you, has your battery been dead or replaced lately?
1 - 8 of 8 Posts
